My friend's 2009 Fit had about 5k on a fill of Valvoline 5w-20, conventional. The Honda Maintenance Minder system still showed 60% oil life remaining.
I noticed that on cold starts, the engine was very, very noisy until warm. By noisy, there was a noticeable amount of engine clatter until the engine warmed up. And even after the engine was warmed up, the clatter was occasionally noticeable. The engine also sounded rather rough, though I understand this to be very subjective. I checked the oil and it was full, though the oil was very dark and smelled a bit burnt.
So I took the car to the Honda dealer for their $19.95 oil change special. 4 qt of new CP Genuine Honda 5w-20 and a new OE filter later, the engine is noticeably quieter. The same result occurred when I did an oil change on this car last year-- when I drained out a 10k old fill of Pennzoil 5w-20 and replaced it with Valvoline SynPower 5w-20, the engine became noticeably quieter. Though, I don't know if the improvement was as significant that time.
This is a bit disturbing to me, as I have never noticed a significant reduction in engine noise after an oil change until now. I may be wrong, but my gut instinct is telling me that even with normal use, the 5w-20 is breaking down after a few thousand miles and is not providing good lubrication. Otherwise, I am at a loss to explain why the engine is significantly quieter after an oil change.
Has anyone else experienced similar issues with 5w-20?
Thanks.
Thanks.
