Yankees, yes, just about any oil is suitable for 3,000 mile intervals … but if you have an high performance car which is going to see load or high RPMs, it’s best to go with something a little better than the really cheap stuff. Either a superior But, if you are set on 3K intervals, I wouldn’t waste time or money looking for a better oil than Mobil 1 SuperSyn. That stuff is probably overkill even at 4K mile changes.
The great thing about frequent oil & filter changes is you flush all the contaminants out with the old oil … acids, salts and abrasive particles. Having said that, I prefer to use a really premium oil like Red Line and extend the interval a bit to help compensate for the higher cost.
![[I dont know]](/forums/graemlins/dunno.gif)
I’m another who
likes to change my oil. Not a bad way to kill a Saturday morning. I do other garage-related things while the oil is draining so I’m not merely wasting time. What I DON’T like is taking the used oil back. This is a pain and at least once, I had a nasty spill in my car before I got to the reclamation center.
![[Freak]](/forums/graemlins/freak2.gif)
As for oil testing, yes, I do think you’re foolin’ yourself if you think it’s a cost effective way to save money by prolonging oil changes. The cost of the test itself is as much or more than most do-it-yourselfer oil changes. However,
occasional testing can verify if an oil is worth using or whether your engine has some other problem … like my car’s head gasket leak.
![[Frown]](images/icons/frown.gif)
Doing one test per is a reasonable middle ground. Spend $20-25 to see how things are going … especially with a hot chunk of iron.
![[Big Grin]](images/icons/grin.gif)
Lastly: oil recycling. I do this too. I tend to change the oil out of some power equipment when it’s still in nearly-new condition. Let’s say I get 1.5 quarts, I let this sit for at least a week in a clean container (so any floaters and bits of junk settle on the bottom) and then I’ll pour 1 quart off the top into a clean, empty quart container. This I use to top off some of the oil burnin’ iron we have (or used to have). If I’m not gonna have a sample of my oil tested, I’d even use this stuff in my car if I know I’m within a couple weeks of an oil change. I figure the biggest/worst contaminant in clean used oil is moisture and this should evaporate off the first time the new host engine is brought up to full temperature and kept there for a half hour or so
Bror Jace
