Here's an interesting Mobil 1 story for you. See analysis attached. on the 11/04/00 oil change, the car got it's first Mobil 1. Lead and iron were high. The guy at Blackstone said he had seen this before on changes to Mobil 1 but that it would still be a good idea to sample it later. Note that the sample mileage is 5000 mi. I changed out the K&N for a paper air filter and silicon went down. On the next samples at 2940 and 1800 mi., respectively (the oil was changed each time), lead levels were 16 and finally 7, which is normal. I should mention that some of the high levels of metals on the bottom of the sheet are oil additives, ignore these readings. Next oil sample is 31k mi. later with 4944 on the sample and, guess what, lead level is 46. Based on the insolubles, fuel dilution, etc., this oil isn't even beginning be old-so why is the lead level so high? Based on the prior results, I'll be willing to bet that the lead levels at 3K mi and 2K mi on changed oil will be just like last time. Anybody got any ideas? This car is a daily driver, never used in competition and has absolutely no aftermarket additives of any kind.
