Oil an dgas mixed
New York
Hi guys. got an lt 133. Mowing with it today, it got real loud. drained the oil, its has gas in it, a good amount too. Would this be a piston ring gone, or something more serious? Thanks
Michigan
If you have an oil and gas mix ..sounds like the oil may have seperated out and need to drain it and get a new mix into it ASAP.
New Jersey
^^^^ What countryboy said. I left gas in the tank of my Craftsman tractor over the Winter. When I drained the oil this Spring, I got 2.5 quarts of gas & oil out of an engine that only takes 1.5 quarts of oil. I rebuilt the carb, but also added a manual fuel shut off valve so that can't happen again.
SW MN
I was going to suggest a fuel shut off too. On my snapper I have to shut it off every time because the pin that holds the float is broken where it will leak but it isnt a problem with the engine running because of the vibration. To me it sounds like it happened when ranger was using it. Ranger can you tell us if the oil level was right when you started?
