- Messages
- 13
- Location
- Nacogdoches, TX
Hello all, new to the forum here. Well, I have a 1990 Mazda pickup with the 2.6 liter fuel injected 4 cylinder and 164K miles. I have had it for the past 80K miles and it has always had dyno oil in it. The truck is supposed to use 10W30. About 2 years ago I began using Valvoline High mileage oil in 10W40 from advice of a mechanic because at the time it was using a quart every 3K miles. These engines are know for losing oil past the valve guide seals. I did that for a year and then just went back to using 10W30 in Castrol GTX. I never noticed a decrease in oil consumption and at this point it is using a quart at about 2600 miles. It does not seem to smoke any when consuming this oil. I still consider this acceptable but it is increasing some over the past couple of years. The truck gets used mostly on 25 mile commutes back and forth to work which is mostly highway and it is used only in eastern Texas. I am a big fan of synthetics but never switched due to the typical stories out there about switching over in a high mileage vehicle. I would like to know of what advice you have in which type/grade/brand of oil to use and if I should do the Auto RX. Also, I would like to switch to synthetic if it is possible. Thank you in advance.
[ January 05, 2004, 12:35 AM: Message edited by: Robert M. ]
