Originally Posted By: Bladecutter
Quick question:
I went to your thread on the Ram forum, and you linked to a video of someone taking a high pressure power washer and hosing off the top end of the engine.
Did you actually do that to your truck, or was that just for comedy?
BC.
Yes.....that was me holding the washer, is there a problem?
Anyway I now have 15-40 rotella and a high cap fram and the engine seems to really like the heavier oil.
Oh, nothing.
Just wanted to point out to everyone here that you used a high pressure water sprayer into the top end of your engine. I don't think that's usually a recommended way of cleaning sludge out of the top end of an engine.
You know, with the possibility of damaging parts like the valve stem seals, I might not have chosen that way to go about cleaning things.
BC.
I'm fully aware of that, however the way the valve stems are set up I would have to spray almost directly downward and intentionally under the rockers. Otherwise they are fairly well shielded by the rocker arms plus I did not have the pressure all that high.
Also in grand total if I fried a valve seal so what? It had 250k on so I'm sure that any damage done would have had very little effect on it at this point lol! Also I really did not feel like having to change the oil like crazy and stuff and just wanted all the sludge gone NOW. That's really it, I knew the engine could take it so I did it lol.
