Hi just got my second block for my 86 Corolla from GM Fedex destroyed the first one.
This is a new Toyota 4A Short block not rebuilt but new from Toyota engine factory.
Anyway the manual says for 1986 use 10W / 30 oil for general all season use in my climate around zero to a bit below in the winter for short times and over 100 in the summer ack. It also suggests 10W / 40 or 10W / 50. Will start off with dino for a couple hundred miles then run dino again for a while and then switch back to Red Line.
Manual says 5W / 30 for less then 50 F Am wondering if I can start using 5W / 30 all the time with the new and improved oils out there or anybody got other suggestions.
Ken
