We had more information on that in a prior link, do a search and I'll bet you can find it. It was extremely enlightening and also schaeffers has met the requirements
Supreme 7000 SAE 5W-30 meets and exceeds the following specifications and manufacturers' requirements: MIL-46152E, CID A-A-52039B, API Service Classification SL, Energy Conserving, ILSAC GF-3, Ford M2C153-G, General Motors, ACEA A1-02, A2-96 Issue 2, A3-02, A5-02; Daimler Chrysler 229.1, 229.3, MS9767; JASO JIS K2215TD-701
Supreme 7000 SAE 10W-30 meets and exceeds the following specifications and manufacturers’ requirements: MIL-46152E, CID A-A-52039B, API Service Classification SL, Energy Conserving, ILSAC GF-3, Ford M2C153-G, General Motors, ACEA A1-02, A2-96 Issue 2, A3-02, A5-02; Daimler Chrysler 229.1, 229.3, MS9767; JASO JIS K2215
Both of the above is the blends, but also some fo our minerals do as well.
Micron Moly® Engine Oil SAE 5W-30 meets and exceeds the following specifications and manufacturers’ requirements: MIL-46152E, CID A-A-52039B, API Service Classification SL, Energy Conserving, ILSAC GF-3, Ford M2C153-G, General Motors, ACEA A1-02, A2-96 Issue 2, A3-02, A5-02; Daimler Chrysler 229.1, 229.3, MS9767; JASO JIS K2215TD-701
Micron Moly® Oil SAE 10W-40 meets and exceeds the following specifications and manufacturers’ requirements: : MIL-46152E, CID A-A-52039B, API Service Classification SL, Energy Conserving, ILSAC GF-3, Ford M2C153-G, General Motors, ACEA A1-02, A2-96 Issue 2, A3-02, A5-02; Daimler Chrysler 229.1, 229.3, MS9767; JASO JIS K2215
