- Messages
- 34
- Location
- West Palm Beach, FL.
I understand some manufacturers are using syn's in certain vehicles off the assembly line i.e. Corvette's, BMW's, and Porsche's. Can anybody collabarate this? If so, wonder what type? ![[Patriot]](/forums/graemlins/patriot.gif)
quote:As far as I know, VW of North America uses Castrol Syntec which is just Group III. I believe VW of Europe uses Castrol SLX - or something like that - which is the "real" synthetic. Regards, Oz
Originally posted by Howard: Don't forget Volkswagon. They use a 5W-40 formulation made by Castrol.
quote:Chevy started this in '93. I was under the impression that it was done in the interest of saving the weight of an oil cooler. The crank on all 3 versions of the LT1 are identical so it seems they would have done this for GM F/B/D bodies also.
I had it on pretty good authority that the original change to M1 in the Corvette a few years back was because of poorly drilled oil passages in the crankshafts.
quote:LOL...yep, CF rated Group 3 sludge is what VW wants us TDI'ers to use. That way we'll be sure to be repeat customers because only VW dealerships carry 5w-40. And don't forget the repeated EGR and intake cleanings thanks to Castrol as well.
quote:In addition to the high temp/high shear test, I thought that ACEA A3/B3 included tests/standards for shear stability, evaporation loss, foaming tendency, deposit control, oil thickening, sludge control and wear. Is that not the case? Do these tests not mean anything for the US driving style? I was lead to believe that ACEA A3/B3 meant that an oil was good for high performance and/or extended drain. I'm here to learn. What do the experts say? Jack
This is simply a matter of the required high temp/high shear (HT/HS) viscosity.
