i had ordered redline p/s fluid for my '96 vette. i auto-x it and change the fluid frequently. after placing the order, someone at redline told me they prefer their D4 ATF in my year corvette. i emailed myoilshop and they changed the order prior to shipment.
immediately after swapping to the D4 atf, i noticed a metallic, random jingling noise from the front of the engine. even though i happened to notice this immediately upon starting the engine after the p/s fluid swap, i figured i just never noticed the noise before and it was a coincidence.
over the past 1000 miles or so, the noise became worse. i started to worry that it was something internal to the engine, sounding like it was coming from the timing chain cover area (the p/s pump is in the same general area). since the water pump had just started to leak a tiny bit, i thought i'd change it, hoping its bearings were going. but, no change in noise after the new pump.
this weekend, on a whim, i swapped the p/s fluid back to the GM recommended part number (i think it's labeled "cold temperature synthetic p/s fluid," or something similar). start the engine, and no noise. gone.
2 coincidences of this magnitude make me think the redline was causing the noise. i have no idea why.
just fyi.
-michael
just fyi.
-michael
