I just recently replaced my LCA's and Sway Bar End Links. I've now noticed two things, the car steers effortlessly - as in there is zero resistance in the steering wheel. It's almost as if I'm on an alignment rack with those swivel plates or on an icy road. I've been told this is normal with moog ball joints and not to worry. (I ended up getting moog control arms) There is no play in the steering, it is very responsive. Castle nuts were tightened, then I kept turning them until the bottom of the cotter pin hole was visible though the notch in the nut. Ball joints were also greased.
The other issue is that when I corner at higher speeds - 20-25ish mph - the car has a bit more understeer that I'm used too. I'm assuming this is due to the longer sway bar end links. I used the moog K700527. I know those speeds are a little high but I had no issues before the sway bar end link install.
Car is currently at a shop getting checked for a transmission leak under warranty, and I asked the shop owner to check the control arms over for me just to make sure everything was done properly. But I'm wondering what the issue could be?
