- Joined
- Dec 3, 2024
- Messages
- 2
Basic concept is when pulling a car battery to repalce or in my case to change an alternator, you use an ODB2 memory saver to give 12v power to car computer thru the ODB2 diagnostic port. Lots of more expensive devices that do this:
https://ezred.com/product/automotive-memory-saver/
Cheaper versions just supply the power thru another vehicles cig power connection OR use any other 12v source (like a one on a portable power bank charger). Im using this memory saver cable, known brand.
OBDII Memory Saver Cable - Schumacher Electric
Im using one of these Jackery Power Banks with cig-style power outlet.
Out of curiosity, I used a volt meter to test the "12v" power outlet and it reads 13.3 :^/
Is that a ifference I should be worried about? Some people use the battery that is removed from the vehicle to power the memory saver, and thats never exactly 12v either. But not really 13.3 either.
Sent email to manufacturer of the Schumacher device to see what they say. But I would expect they would play it safe and say only use with 12v. But exactly 12v?
