O2 sensor lifespan
Saudi Arabia
Elantra MD 2.0Nu DOCH MPI
o2 sensor never replaced gas smell from exhaust in cold start recently, acceleration is seem sometimes good sometimes sluggish car pass HC 7PPM & CO 0% in my country they don't have nox I got only one o2 which is upstream one car mileage 223,000 suptorpical climate
Winter 35.1mpg with 424 miles range
summer 36.2mpg with 460 miles range
do o2 sensor need replacement asap or wait for full failure
No CEL Light, obd live data long fuel trim 0% avg and short trim float between 0 and -95 stay at -95 mostly voltage reading from 0.95 till 0.89 depends on driving conditions I know -95 is weird because engine performance not bad I don't know if this reading accurate or obd malfunction
I don't see anything wrong with the figures you mention. The O2 sensor's signal is basically ignored by the computer on a cold engine (open loop operation). I would leave them alone.
If you do replace the O2 sensor make sure it matches the original. There are the old style 2 wire, 4 wire, and heated O2 sensors.
OEM part are renew not like the old one I'll check it out, I'll leave it till pre failure symptoms I drove the car mostly at highway 77mph weekly for 100mile
I've replaced a number of O2 sensors on my high miles Ford trucks due to slow response. They were still functional, but every few months would generate a check engine light and OBD2 code. I did see a small increase in MPG when they were changed.
Great results, I think mine maybe slow lazy sometimes no maintenance schedule for this part but I'll check the new one match the old if so I'll replace it
