Hello internet and BITOG faithful. here is the goss from downunder.
Nulon over priced their race oil products ($110-120AUD/5L.) As such they were not real stock turner's. Thus last week SuperCheapAuto did a runuout to clear inventory at $48/5L. As such I snapped up the last 3 5W30 5L tins in South Australia. These oils are rather unique in their base oil composition containing a blend of POA's (G-IV) and the rare Alkylated Naphthalene (G-V) base stocks. They even have a slightly different smell to them as a result. Colour is a typical maple syrup brown, rahter than the light honey of say a Shell Helix Ultra GTL oil.
Of note is that Nulon DO-NOT rate this oil by either SAE, ACEA or any other OEM standards.
here is the product:
Product page can be found here
Product bulletin can be found here
and MSDS can be found here
As nulon have been rather tight lipped about their product I thought I'd get a VOA done at my local CAT dealer.
As you can see it's jam packed full of ZDDP, has near as makes no difference 700ppm Moly and 100ppm Boron. Mostly a Calcium based detergent package with a little both of Manganese for good measure. This will be the duty oil in my soon to be tuned GTiR pulsar. Should do the trick. With a TBN close to 10 and a VI of close to 170 it looks to be a robust package. But definitely not a low or mid SAPS oil... With a 100°C viscosity of under 10, it's fairly typical of modern 30W oils. but with that high VI number, it should hold that viscosity better as the going gets tuff,
Regards
Jordan
Regards
Jordan
