Anyone know how these are retained. You can see some of the input rollers came out and got ground up thru the planetary assy. (The swarf in the pic is largely shift fork pads which worries me far less)
Anyway, the outer ring moves fore/aft just barely, is this a concern? I can't seem to easily get it out but it's not a press fit if I can move it by hand.
I have a donor case where the same ring is tight, or at least can't be moved by hand.
It should only see use in 4lo but still this truck does see 4lo sometimes
