i just changed my oil today... switched from mobil 1 10w30 to mobil 1 15w50...with supertech filter.
Now the car knocks...whenever. No leaks, oil full, everything seems fine... happened RIGHT after the oil change.
I have a hunch its the super tech? since it has the rubber thing over the small holes,(antidrainbackvalve?) maybe its restricting flow or something... never had knocks with the delco PF58, which has no rubber blocker under the holes...
any suggestions? It seems to be coming from the underside of the car...like a bottom end knock, cant hear it in front of engine, mostly when i open the door and lean over...
