I think you'll find that 36 psi = 2.5 bar
And to clarify:
P metric tires (US based standard) use 35 psi as the end point for the load table
Metric tires (European based standard) use 36 psi as the end point for the load table.
Metric tires (Japanese based standard) use 35 psi as the end point for the load table.
The end point of the load table is not to be confused with the maximum pressure put on the sidewall.
Confusing? You bet!! One of these days we'll have a worldwide standard, but it's taken a long time to get this far, and we have a long way to go!!
Hope this helps.
