Originally Posted By: Hitzy
Yes....xW-20 & xW-30. I know they are both suitable for temp an engine will reach under normal operating conditions, I'm not trying to make this a complicated question, just asking which has the ability to protect to a higher temp.
If you want an example, how about if you get a stone through your rad and for some reason can't pull over right away and your engine overheats. Which oil would protect better in an overheated engine situation?
It probably still depends upon which type of oil (as distinct from vis grade) and what sort of engine has the problem. For example, I suspect that Redline 0w-20 would probably stand up to an overheating better than a thick G-II 5w-30. As for engine design, probably depends upon how tolerant a given engine is for its oil thinning with heat. If the design is intolerant of thinned oil, perhaps the 30 wt provides an extra margin over the 20 wt. If the engine "doesn't care" then no added advantage. In short, it's not about a given oil's grade and makeup looked at in isolation, it's how the whole thing works together. IMO.
Originally Posted By: BuickGN
What it may come down to is HTHS. It's been proven though some still debate it that a higher HTHS will protect better under high heat and stress. Most 30wts will have a higher HTHS than most 20wts. To all you thin guys, notice I said "most". No need to bring up Redline.
I already mentioned Redline.
I too keep an eye on the HTHS values. Personally, I suspect that on this dimension, engines fall roughly into two categories -- those that respond to different HTHS values, and those that don't (within the bounds of reason, I suppose you could make any engine respond by going to extremes). For the former category, owners might see a difference; for the latter, they won't.
At the end of the day, however, even if one concludes that on some level 30 wt oils generally protect better than 20 wt oils (whatever "better" means), it must be on a level of virtual insignificance. Again, over eight years since the xw-20 oils became widely specified by car makers, and we're still not seeing any indications of automotive engine destruction as a result. I suppose the counter-question for all you thick oil devotees is this: where are all the junkyards full of dead Fords and Hondas that were killed by their thin oil???
