i came across this on honda-tech;
What's interesting is that firmer shifts generally means less slippage on the clutch packs/friction surfaces.
This would be interesting if say using mobil 1 ATF was the ghetto equivalent of putting in a shift kit on a honda auto tranny.
More comments always welcome.
http://www.honda-tech.com/zerothread?id=1195661quote:
Honda's mission with their own transmission fluids is to develop a single common fluid that will work in all of their transmissions.... That is auto, manual, and CVT. A friend of mine who used to work at Honda on transmissions sites several fluid evaluations where dexron comliant fluids were tested in the Honda transmissions, and it increased the torque holding capacity of the transmission by a noticeable amount. It also produced much firmer shifts. Basically... if you want to tow a trailer behind your Odyssey or Pilot, you should switch to a dexron fluid. The tests on the dexron fluids also showed no difference in durability.
