I have a 56 chevy with a 283 in it. Ive used non detergent oil straight 30 for many years but can't seem to find any replacement anymore. Any suggestions would help greatly. Thanks.
NAPA, Tractor Supply, Runnings, etc. all carry ND30.
Not sure why you would want to run that though. You've run it for years and may not be able to, but I would pull a valve cover and see if it's clean enough to run a modern oil.
In the past ND oil was oil that had antiwear addaitives but no detergent. The ND oil sold today had zero antiwear addaitives. You are not doing the 283 any favors by running that oil.
The 283 should have a filter. The Fram # was CH 200pl and it went inside a can that bolted to the block with a long bolt.
