I seen that but even Chevron's SAE30 is thinner than that, so if it's used in SAE30 formulations it must be blended with other thinner more volatile base oils. Probably used more so in SAE40 formulations, while MAG1 supposedly uses Exxon EHC base oils, their SAE40 formulation list the NOACK at 2.8% which would put it more in line with the base oil have only a 2% NOACK. Do the additives used in oil have a slight thickening effect that when make a base oil just on the edge of SAE30 viscosity it would make it too thick to be an SAE30 still?
