My suggestions, by the way, depend on if you have a Tecumseh engine made in the last 7 - 10 years.
Shut off gas supply via valve or pinched line. Unscrew bowl nut that holds bowl on. Pull off bowl and wipe out well. Look at bowl nut. It has a hole right down through the middle that needs to be checked for blockage. A stripped bread wrapper will poke through and clean it up. Carb cleaner will blow through and help out too. The two larger holes at the base of the bowl nut shouldn't be a problem, but look through to make sure they're clear. The tiny pinhole on the side, towards the tip of the bowl nut, right above the threads, needs to be cleared also. You can reassemble and run it or do one more thing.
Another quick step to pretty much finish your carb clean is to...Look at the side of the carb. Notice the round spot where an adjustment screw would be on older models. The round thing you're looking at is a little plastic cup that covers a screw. Trash the cover and take out the screw. While the bowl is off, squirt carb cleaner through the screw hole. It should come out of the bottom of the carb. Then, make sure the holes in the screw itself are "poked" out. The bread wrapper will work fine there too (I use a torch tip cleaner). The screw just goes all the way in...it's not an adjustment. Reassemble and have fun.
AND, you know...since you have the bowl off and the gas will flow freely from the tank and out of the carb, this is an excellent chance to empty the tank of older gas…most of it anyway.
