For the last 3-4 tanks, I've run Super Unl 93 oct gas(ethanol) & the Superchips Performance tune(91 octane req) in my 02 Dakota 3.9 V6 ATx. All gave mid-17s mpg.
Turns out there's a small independent station ~8 miles away claiming No Ethanol gas.
After a talk with the owner, yesterday I began an experiment. I filled the tank with their Regular- held 19.94 gal + ~4 oz Fuel Power, into a 22 gal capacity tank. I then reset the Superchips- but instead of setting it to the 87 octane tune, set it to Towing(91 oct req) instead. That should have more timing advance than the 87 oct tune, but less than the Performance tune.
Have driven it about 45 miles since then. Maybe it's the 2 gal of Super left in the tank, or the FP, or the combination, or ?- but so far not a hint of ping/clatter.
I may be playing with fire, but figure if it does begin clattering I can always pull over & reset the Superchips to the 87 octane setting.
And FWIW- the Dodge 3.9 V6 is something of a known "shaker". It now idles smoother than it has since I bought it 6 months ago.
Real gasoline- what a concept!
