Originally Posted By: Kestas
I thought aircraft wheels used nitrogen because you can't get an air compressor to deliver 300 psi like you can from a cylinder of nitrogen. And unlike an air compressor, the cylinder can be brought to the aircraft.
I use nitrogen wherever required but, most of the aircraft I work on only require ~175psi tire pressure, which could easily be supplied by a decent compressor. Around 95% of the time the tires are serviced within the hangar and an air hose is a whole lot lighter and easier to get around than the nitrogen cart.
AFA my car's tires, well, they all get whatever my Husky air compressor kicks out.
