had a trip of a couple hundred km today to meet my Mum...didn't make it, turned back with some issues.
Heading up a hill, the ute started a big "whooshing" noise, like an electric blower effect. Turbo wistle increased markedly also...Son in the back seat remarked "what was that".
Stopped and started troubleshooting to see if the trip was viable, or should be abandoned, given rubbish weather at the moment.
Found that the hoses connecting the turbo to a distance piece, and onto the manifold were a little loose, and there was clear evidence of an oil mist (crankcase breather fumes) covering the top of the cam cover, and having made it's way to the brake booster...wasn't there last OCI, nor there 3-4 weeks ago when I showed daughter how to check the oil and fluids on that one.
Tightened them up, and some of the wooshing noise was gone, but the turbo whined similarly...abandoned the trip and came home.
Partially blocked the air intake (hmmm, not the best idle, it broke the screen of the snorkel - can be fixed), but while the induction system was under vacuum, ether didn't change RPM at all...top hose connector was pretty squishy, so I replaced it on spec.
While the pieces were off, I started it, and the turbo provides at idle about a hair drier's worth of volume/pressure, so really not sure at all that I had vacuum in the intake.
Checked the EGR plate that I made and fitted all there and intake, gasket good.
While messing, I pulled the "throttle body" (it contains the shut off butterfly and the EGR/Swirl butterfly on these). Gasket good. the low swirl intake port was perfect (small oil film), the high swirl/EGR port lined with black "grease", that was quite thick, and smeared well on finger...residual carbon from EGR days.
Pulled the intake to the turbo, and the turbo (149,800km) was very tight, no end or radial play felt.
Pulled the heat shields off half of the exhaust manifold to have a look see. Interwebs indicate that an exhaust leak creates the whoosh, AND increased turbo whine...the shield that you can get off is over 3/4 exhaust runners, and is the usual failure point - 1 and 2 require the turbo off just to look-see.
No signs of failed gaskets on where I could see, but I doubt that a half hour and 25 miles is enough to make a noticeable stain as yet.
Thinking that having gone right over the air side, I'll leave the shields off and see if a carbon stain develops.
So...any ideas ?
So...any ideas ?
