Hi everyone,
I'm a new member here! I've been reading these forums for a long time, and there is some really great info posted on these boards.
I've been reading a lot about the Nissan VQ35 engine, as I own a 2005 Altima 3.5 5-spd M/T, bought brand new in April 2005.
I've been using Amsoil 0W30 Series 2000 since the car had 2000 km on it. It runs great with it, and I will be doing some UOA soon to see how things are doing.
However, I came across the following image in a Maxima forum. It contains the recommended oils for a European model VQ35 engine as given in the European owner's manual (see pic below). I was surprised to discover that the recommendations are quite different than those in my manual here in Canada.
My manual recommends 5W30 for all temps, and states that 10W30 or 10W40 can be used only for higher temps.
As you can see in the pic, the European owner's manual has quite a bit more selection of recommended oils, more on the thicker side by my eye. It also states that 5W30 should only be used below 15 C! I found that particularly interesting.
What do you guys think of this? I've read posts on this forum stating that VQ engines seem to prefer thicker oil, although that is debatable as well. Do you think that Nissan North America is simply trying to improve their CAFE level and is not thinking about engine protection as a primary consideration?
I was thinking of moving up to Amsoils 5W40 Euro formula for the summer months, and switching to 0W30 series 2000 for the winter. Thanks for the comments in advance
http://server6.theimagehosting.com/image.php?img=Euro Specs.jpg
EDIT: Sorry, I don't know how to make the image display here. The link is given above. Thanks!
