Equipment Make: Nissan Titan
Equipment Model: 5.6L V8
Fuel Type: Gasoline
Oil Use Interval: 3212
Oil Type & Grade: Castrol 10W/30 SL
Miles On Oil 3212
Miles On Unit 12312
Sample Date 09/14/06
Castrol 10W/30 Universal Ave
3212 miles
Aluminum 5 3
Chromium 1 1
Iron 5 12
Copper 3 5
Lead 3 4
Tin 3 1
Molybdenum 76 70
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 0 0
K 0 0
Boron 2 62
Silicone 13 13
Na 2 10
Ca 1632 2130
Mg 9 105
P 711 722
Z 793 847
Barium 0 0
SUS Vis 65.0
@210 F
Flashpoint 410
Fuel Antifreeze 0
Water 0
Insolubles 0.3
Blackstone Comments: Universal averages show typical wear metals for an oil from this type of engine after about 4950 miles run on the oil. Your oil was in use 3212 miles, and we found all wear metals at around average levels and in the correct balance to show normal mechanical parts inside. Air and oil filtration appear normal. Silicone was Ok showing adequate air filtration and the 0.3% level of insolubles indicate good oil filtration. This was a 10W/30 engine oil with no fuel, moisture or antifreeze in it. Nice wearing Nissan at 12,312 miles. Check back to establish trends.
My comments: My first UAO btw. This was my 4th 3K run for break in. No TBN due to the shorter interval. Oil and air filter were OEM. I think I will change the air filter soon. I have a fill of PP 5W/30 with a Wix filter in the truck now I’ll probably take to 5K and check with a TBN. This truck was broken in gently with a lot of variation in RPM's (it's easy here in the mountains) and no load placed on it for the first 1000K miles (though I would occasionally take it up to 4 or 5K rpms wihtout a load). I drive the vehicle gently though after I passed 10K I did a lot of WOT's for ~ 90 miles to complete any high rpm aspect of the break in.
Comments are welcomed and appreciated.
Fuel Type: Gasoline
Miles On Oil 3212
Miles On Unit 12312
3212 miles
Aluminum 5 3
Chromium 1 1
Iron 5 12
Copper 3 5
Lead 3 4
Tin 3 1
Molybdenum 76 70
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 0 0
K 0 0
Boron 2 62
Silicone 13 13
Na 2 10
Ca 1632 2130
Mg 9 105
P 711 722
Z 793 847
Barium 0 0
SUS Vis 65.0
@210 F
Flashpoint 410
Fuel Antifreeze 0
Water 0
Insolubles 0.3
