I'll just put this whole thread on IGNORE
... where is the button for that ... ?
Kia wants oil changes every 3750 miles or six months for severe use, just about everyone is in the severe use category.
This big shot from Nissan says to do 2000 mile oil changes.otherwise extreme damage is being done. Thoughts?
That is for normal use, which no consumer falls under. 5,000 miles or sooner for extreme usage. That’s what all consumers fall under.That is not what their owners manual says for the 21 Altima. It states 10,000 miles or 12 months, whichever comes first and that is exactly what I do.
BS. My Altima is all HWY 5 days a week. Normal use. All consumers DO NOT fall under extreme use.That is for normal use, which no consumer falls under. 5,000 miles or sooner for extreme usage. That’s what all consumers fall under.
So you drive your car nonstop, no idle, no traffic lights, no extreme cold, extreme heat? You crank it up, and are immediately on the interstate and when you get to work you are immediately off the interstate and that’s it?BS. My Altima is all HWY 5 days a week. Normal use. All consumers DO NOT fall under extreme use.![]()
Is it a European car?Probably why my 500,000 km car with 10k ocis has the body rotting around the engine. 🤣
Seriously, dude. You can't be serious. Some idling, heat, cold, etc but mostly hwy does not constitute extreme use. 10,000 mile OCI's have been done for years on vehicles that have gone on to hundreds of thousands of miles. This old school thinking needs to die.So you drive your car nonstop, no idle, no traffic lights, no extreme cold, extreme heat? You crank it up, and are immediately on the interstate and when you get to work you are immediately off the interstate and that’s it?
Listen weasel, you fall under the extreme category. I have worked at Honda, Toyota, Kia, BMW, VW, Mazda, Ford, Nissan and GM as a tech. It is not old school thinking, it’s called seeing what it does to engines and the issues it causes. The only manufacturer that actually keeps the 10,000 OCI is the euro ones and even those are really not recommended to go the full 10,000. Euro oil has nothing in common with API, or ilsac rated oil as they use way better oils and higher HTHS. Every other manufacturer tells customers not to follow the oil life monitor and puts a 5,000 mile sticker in the car. The only reason manufacturers try to push extended OCI is due to keeping the cost of ownership down. They also say coolant and trans fluid is lifetime. Just like the 20 weight oils are only for CAFE, not for full protection I mind. See if you actually read the fine print in the owners manuals, it says everything I am telling you about extreme and normal usage. Please don’t tell me either it’s a way for the dealers to make money bc a dealer makes absolutely nothing on oil changes.Seriously, dude. You can't be serious. Some idling, heat, cold, etc but mostly hwy does not constitute extreme use. 10,000 mile OCI's have been done for years on vehicles that have gone on to hundreds of thousands of miles. This old school thinking needs to die.
Wow. So, you have resorted to name-calling? Such a professional.Listen weasel, you fall under the extreme category. I have worked at Honda, Toyota, Kia, BMW, VW, Mazda, Ford, Nissan and GM as a tech. It is not old school thinking, it’s called seeing what it does to engines and the issues it causes. The only manufacturer that actually keeps the 10,000 OCI is the euro ones and even those are really not recommended to go the full 10,000. Euro oil has nothing in common with API, or ilsac rated oil as they use way better oils and higher HTHS. Every other manufacturer tells customers not to follow the oil life monitor and puts a 5,000 mile sticker in the car. The only reason manufacturers try to push extended OCI is due to keeping the cost of ownership down. They also say coolant and trans fluid is lifetime. Just like the 20 weight oils are only for CAFE, not for full protection I mind. See if you actually read the fine print in the owners manuals, it says everything I am telling you about extreme and normal usage. Please don’t tell me either it’s a way for the dealers to make money bc a dealer makes absolutely nothing on oil changes.
Why ‘Severe’ Drain Intervals Should Be the Norm for Most Drivers
In many cases, there's a big difference between the "normal" and "severe" drain intervals. Use these tips to talk with your customers about which category they fall into.www.noln.net
