I'm planning a drain and fill when things warm up. My PU trans has a 8.3 qt capacity and it appears you can only get about 2.5 qts out per drain. I was planning on at least 4 drain and fills. My question is how many miles should I drive between drain and fills. I assume it should be long enough for a thorough mix, but not sure how long that takes.
