Nissan Matic-K in '96 Lexus
Alabama
Have four quarts of Matic-K that I was thinking about using in my daughter's ES300 when I do the next drain and refill. What say ye?
Well, this is the first I've heard of someone wanting to try this in particular! smile IDK! Although, if the '96 Lexus uses DexronIII/Mercon and not T-IV, who knows! My sisters '98 Camry V6 is essentially the same as the ES-300 and uses DexIII/Merc It's a gamble but, I don't see why it would hurt. "If" T-IV is backward compatible with that tranny then maybe the friction modified Matic-K may not change the shifting pattern either. Just out of curiosity, I always wanted to try a full D&F or two of Chyrsler ATF-4 in my wifes Lexus RX instead of the T-IV. I haven't yet!
Yeah, Char Baby, it calls for DexIII, and I think I've read that the Matic-K was proprietary but very near the DexIII(H) spec. It only drains 2.5 quarts, so I think I'll try it. I'll report back after I have a chance to drive it.
Wow, smile I haven't seen the(I beleive it was actually called Dexron II "H") spec in years as it was only out on the market for a short time before DEXRON III/Mercon hit the shelves. I believe the order of DEX ATF's were, (and I could be wrong on some of these): Dexron Dexron II Dexron II "D" ???(Never seen this one, only heard it existed!) Dexron II "E" Dexron II "H" Dexron III(IDK if it was always called DexIII/Merc) Dexron III/Mercon Dexron IV(I've never seen DexIV, only heard it existed!) Dexron V ?(I think the "V" was skipped over?) Dexron VI(current Dex ATF) But anyyyywaaayyy! I think you'll be just fine. smile My sisters '98 Camry V6 auto tranny also only held ~ 2.5 qts on a drain/refill so, we did it about every year. Sold in '11 and everything was running fine using Wal*Mart SuperTech DexIII/Merc since '01.
