Originally Posted By: paulswagelock
Originally Posted By: NHHEMI
OP - why the need for a big mystery? Just post what you did. No need of games and drama. Welcome to the site btw.
I smell a hoax, scam, or advertisement coming....
Sorry guys - just wanted to see if you had the same noise as me and the guy who posted on youtube and if you found a way to make it stop. No scam. Plus it got late and I didn't want to type the following...too long.
Here's what happened with mine. Like I said, bought it new, no noise when cold at all. After being driven to heat it up, it sounded like a tick machine. Probably 7 or 8 of them going at it. Terrible next to a wall at a drive thru. I didn't beat on the truck, but didn't "granny" it either. It got worse. Then I started driving it pretty hard at 3k miles. I began to notice that if I floored it thru at least 3 gears and came back down to idle, it was quiet. For a day at best. Suspecting lifter bleed down, I changed the oil to 10w-30 Pennzoil Platinum like so many of you like. Finally, it had shut up, but only lasted 2 or 3 days. (I'm sure it's a great oil, but my AFM lifters don't like it)
Now I'm furious...new engines don't sound this bad. I thought fine, I'll rev the p*ss out of it. I put the shifter in "M" and floored it and hit the rev limiter at 6k rpms and would shift up and hit rev limiter in that gear, etc. Daggonit, it was quiet again, but short lived. Then on a trip to Pittsburg from Ohio on Sept.18, I noticed at a rest area it's doing it again. I tried an experiment - ran it in "M" 5th gear for the rest of the trip. AFM stays in V8 mode this way, plus the revs are ~500 greater than 6th gear. Pull in hotel. Quiet again. [censored]? Drive home in 6th, pull in driveway, sounds terrible. Mad, I stomp the pedal in Park and hold at 4 grand where the computer holds it for about 30 seconds, let off, it's quiet again. I'm starting to see a pattern here. Checked oil, had not used any, but was pretty darn dark for only 2.5k miles on oil with a new engine containing no sludge.
So...I decide to change the oil again, this time to Valvoline 5w-30 SynPower. Engine was hot and still ticked a bit, but was better. I took it down the road and romped on it hard for about 10 miles. Came home and couldn't believe my ears...dead silence. I mean a silence that's unbelievable. All I hear is the alternator. That was a week ago and about 500 miles. I haven't stomped it since and it's still dead quiet. I saved my Pennzoil - it's going to Blackstone. So is this Valvoline in 3-4k.
Sorry if I sounded like I wanted drama or to sound like I know it all...I don't. I would still like to know if others with GM AFM has a HOT ticking issue. Not cold, those are the earlier design (Eaton I believe) lifters. Mine are Delphi I believe. Again, sorry...and for the long post. Only way to make clear my story.
Jim
Jim
