Originally Posted By: ferrari512
Originally Posted By: Nickdfresh
Successful troll is negative troll!
I'm sure in your obsessive Google-phu, "ferrari", you've probably come across five articles that support the contention that recycled oil is every bit as good, if not superior, than oil refined from crude for every lame article from Aman, Jordan. I'm also sure you must have come to the conclusion that refining used motor oil is now economically viable...
Here's an article in the "Scientific American." You know, actual science...
Originally Posted By: http://www.scientificamerican.com/article.cfm?id=can-oil-be-recycled&page=2
What is re-refined oil used for then?
Franceschi: It's used essentially as a refined crude lubricant. Re-refined oil used to have a bad color associated with it because in the old days they didn't have modern technologies. They did some filtering and poured it over clay. They had these very, sort of, antique technologies. It did not make a high quality oil and it got a very bad reputation.
Today, with modern technologies, you could use it for passenger car motor oil, automatic transmission fluid, hydraulic fluid, heavy-duty motor oil. There's no difference between oils re-refined with modern technologies and refined oil from virgin crude.
This has nothing to do with a paper on in depth analysis on recycled oil using AA technology that is specific for metals or FTIR.
And the paper has nothing to do with Nextgen, as the recycled oil was analyzed with AA over five years ago...
Quote:
You guys be the Nextgen fluffers all you want but there are other people on this site that might change their mind, thats good enough for me.
It was hardly a "paper?" In-depth analysis? It was an abstract article summarizing findings and its conclusion was:
Quote:
They conclude on a positive note regarding the re-use of engine oils. "If these re-refined oils are manufactured correctly, there is then no reason not to use them," they say, "The requirement is, above all, that the re-refining process is perfect and the oils are alloyed correctly just like virgin-base oils."
