OVERKILL
$100 Site Donor 2021
Didn’t really see them or the Cruze in the shops needing much besides the thermostats water outlets and water pumps all of which is pretty easy stuff. As far as not listening. That seems perspective based in a way. Think back to when all the frugal folks would scream DONT GET A CAR PAYMENT. and all the other save money be frugal advice. I did listen to that. I decided I didn’t want to sign my life away for another 6 years or so on a new car and instead wanted to buy a cheaper car in cash. So I did kind of listen. I took that advice and passed up on the long car loan and the fancy new car. I think financially it was a good call. My friend has a Cruze with the same engine it’s been a good car for him.
I THINK it was poster pbm that had the Cruze that he offloaded?
I found this quote from him with a quick search:
pbm said:I hope it really is 'fixed'. I purchased a brand new Cruze in 2011 and had it back to the dealer several times for coolant loss/ coolant odor issues....they denied there was an issue despite 200 pages of complaints for the same issue on Cruzetalk.com. They finally replaced the surge tank with no improvement. I traded it in on a new 2014 Focus and haven't regretted it. Cruzetalk.com had several different hypothesis as to what was causing the problem but nobody ever had it solved. I think it's just a bad design. PS: There was a class action lawsuit on this very issue.
I definitely understand the desire not to have a payment, just an observation that you didn't ask for feedback about this particular car before pulling the trigger, rather, you asked about other ones and then went a completely different direction
In case you want to read-up on the turbo replacement (which I suspect, if necessary, you'd be handling yourself) member @The Critic did one, as well as the coolant parts on the same engine in a Cruze:
2012 Cruze 1.4T Turbo Replacement
We have a 2012 Cruze 1.4T that is coming in for a turbo replacement. Due to mileage, the car is just outside of the 5/100 powertrain warranty. We plan to replace the turbocharger, oil feed line, oil return line, all 6 cooling system pipe seals and the seal between the turbo and the catalytic...
bobistheoilguy.com
