I just bit the bullet and bought a new snow blower yesterday. Last winter just took what was left out of my 1996 MTD 22" snow blower w/ Techumsa motor. I loved that snow blower. Well, more specifically the motor. Best small engine I have ever had.
I really have used it hard over the years and I frankly have been impressed with how well it held up. It ran for 2-4 hours every storm pretty much. Best $479 I ever spent on something like this. The body and drive line have finally just worn out though or are getting there anyway. The motor still starts on the 1st pull and runs good although it is starting to burn some oil. I could probably limp it through a mild winter but another one like last year and it would not make it for what I need it to do.
I have to have a dependable blower as I can not shovel anymore due to illness(MS) so I have been looking for a new snow blower for a couple years now as the MTD got older and began to wear out. It kept hanging on though and I kept saying 1 more year, 1 more year. It was time though and I knew this year was it. Yesterday I was at HD and saw a couple sitting there and decided to pounce while I could after trying to replace it last winter and no snow blowers were to be found anywhere.
I ended up with a 24" 2-stage Ariens Sno-Tek. It has electric start which I don't want/won't use but it seems that is all you can find these days. You almost never see manual start ones here anymore. I had/have concerns about the LCT engine( never heard of them before this - more China junk I guess but short of spending a small mint that is what you get )but I could not justify the expense of buying a different snow blower with a better/known engine for hundreds and hundreds more. It was actually $300 more to buy the top of the line Ariens version of the 24" 2-stage snow blower I got. The same exact thing as the one I got just with a light and a Brigg's & Stratton engine. Same case, driveline, etc... but $300 more.
Hoping I didn't make a mistake? I know this is the economy line from Ariens but Ariens seems to be a reputable company when it comes to snow blowers. As I said above the motor is really the only difference between them. Maybe the paint/powder cooat isn't as good as well. Otherwise it is the same base snow blower as the top of the line Ariens. For $100 more I got an extra 3 years of warranty so I now have 5. If it makes it 5 years without problems I guess I will be happy. It would be nice to see 15+ years out of this one the way I did the MTD but I doubt it. I wonder if it will go the 5 years without issues or if I will need that extra warranty?
What say you, did I make a mistake?
Here are the 2 I considered. As you can see they are basically the same thing except for the engine and one has a light and the other doesn't. The regular Ariens is 1" taller but I assumne that is to accomodate the different cross piece with the light( different handle bars? ). It weighs 4lbs more but that is probably the engine difference and light/different handle bars. Other than that they are the same. The cheaper Sno-Tek with the LCT engine actually has more power and is larger so in theory it should be able to handle a little more snow.
Gues this winter will tell. Probably won't get any snow now.
