New PowerStop Z36 Rotors and Pads
Did some maintenance recently. Removed the RCV front axle shafts and went back to stock. At the same time, I installed new bearing hubs, rotor shields, replaced all bolts, boots, and nuts and installed PowerStop rotors and pads. I can already tell the difference in braking power with just the fronts installed. Rears are next.
If you decide to flush the brake lines, I recommend this:
Probably the best brake fluid for street use.
Also, your braking power comes from the pads. Keep an eye on the PowerStop pads, because the slots in the rotors will wear them out faster than regular rotors.
When the time comes to replace them, if you want to upgrade to something even better, I recommend Akebono Performance Series. I put those with the stock rotors on a RAM 1500 and it made a huge difference in braking power. I also flushed the braking system with Motul DOT 5.1 fluid.
Looks good!
Looks good!
It came with DOT3; I thought there was a compatibility issue with DOT 3/4 and DOT 5.x?
Don't use DOT 5 in your vehicle. It's made from silicon, I believe. Sorry, I didn't invent the naming scheme, it's stupid, I know.
DOT 5.1 is backward compatible with DOT 3 and 4.
Yep; I checked; 5.1 is good to go. Does the Motul have a different color or just standard "brake fluid" clear?
It's almost clear. It's made from esters IIRC. What got me was the low viscosoty when bellow zero and high heat resistance.
Just ordered 4 bottles and a bleeding kit to do it myself. Every shop around here said it was incompatible with DOT3/4, which is what I initially thought, but 2 seconds on Google as well as feedback from you guys clarified it. The shops around here want to use DOT4 which is better than the DOT 3 I currently have, but if I am going to flush it, I may as well go to the highest boiling that I can.
Thanks for the tip!
Awesome! Glad I could help. This is the bleeding tool I used: https://www.amazon.com/Allstar-Performance-ALL11017-Bleeder-Bottle/dp/B00F9XHVKA.
I don't know how much good the check valve does because my wife helped me by pumping the brake pedal and keeping it depressed while I tightened the bleeder screw back. It worked very well for what it is, and the 5-year-old DOT 3 fluid that came out was nasty and black.
I bought the one below, but I intend to do exactly what you did, have my son pump the pedal while I loosen/tighten each bleeder. My DOT3 is only 3 years old, but I expect it will be similar. It spent most of its life in super high humidity in Houston.
I completed the back brakes last night including new emergency brake pads and the ebrake was where the most time was spent. I had to re-use the springs which I did not want to do, but like everything else, they were on national back order. Only the small spring over the "star" wheel was lightly rusty so I just wire-brushed them and added a bit of ceramic brake grease to slow further rusting (though here in CO the humidity it typically very low.
Now to remove all of the skid plates so that I can tackle the transmission filter/fluid and transfer case fluid--glad this isn't a monthly task LOL.
Lots of good info in this thread:
In summary, stick with a quality DOT3 like the ACDelco product in that thread.
@Rod Knock - ran out of time after the transmission filter and fluid change and transfer case fluid change, but I did manage to change the fluid in the master cylinder before quitting for the day.
It was a burnt orange color and has a slight film on it in the container. I will complete the brake fluid flush today and report back.
You're, it looks orange when it's in a transparent container. When poiring it, it looks different though. Good luck with the brake job!👍
Sorry, I was not clear--I meant the old fluid. The new 5.1 is crystal clear.
@Rod Knock - all done. I am about to take it out for a test drive to see how it does. It took 3 500ml bottles leaving me with 1 full and unopened bottle for future. A few pics of the fluid:
First dump:
Intermediate Dump:
Final Dump:
Thanks again for the tip on the Motul!
First dump:
Intermediate Dump:
Final Dump:
That looks nice and clean. The Motul looks clear when you pour it and yellow in a container. That's what I was trying to say earlier. Sorry, it's been a busy few days over here.
I hope it will serve you well :)
For me Motul DOT 5.1 worked well. I also have two quarts of Castrol DOT 4 and when I did the brake fluid on the RAM 1500 I almost went out and got Valvoline from AAP. Brake fluid is not difficult to flush and change.
[Edit]
Motul spec sheet: https://azupim01.motul.com/media/motulData/DO/base/DOT_5.1_en_FR_motul_27400_20220113.pdf
Any brake fluid will work under most climate conditions as long as the fluid was replaced correctly, but there are some fluids with a superior low-temp viscosity that is beneficial under certain conditions. The MIL study in the other thread outlined some differences that was news to me.
