New Peak at Walmart? Are both of these yellows? For Aluminum Headed 351W
Rocklin, CA USA
Which would you choose for a Ford 351 Windsor with aluminum heads? Just saw this Peak coolant at Walmart today.
The Peak Ecoshield is propylene glycol, FWIW
For a very old car, use old green coolant. Peak and Zerex still make green silicate coolant.
Not only that, apparently it is bio-based propylene glycol as apposed to petroleum based propylene glycol. Here is their advertising. The arm chair chemists will come out of the woodwork.
No reason to use old school green. It has downsides too. Simply get Prestone all vehicles concentrate at Walmart and mix it yourself. Saves money, protects exceptionally well. Available everywhere if you need more.
We use the Prestone in everything from personal cars to very high output turbocharged race car engines, and have found it to be perfect. Absolutely no corrosion, deposits or water pump wear. It is a long life product too, so no need to change it out every few years.
I know there are Propylene Glycol products out there that people use, including Evans/Safer/Peak. We've had nothing but disaster with them, including micro-perforations in aluminum.
This Prestone All Vehicles is good with brass/copper heater cores?
