New pan gasket. Install dry or with gasket compound?
chances are you do need to put rtv around the whole gasket, or at least a few dabs in certain areas. it varies so i cant tell you where.
On my Jeep I used a very thin bead of RTV all the way around the pan. I then applied and OEM rubber gasket and allowed it to dry a good bit. I then applied a thin bead all the way around the top of the rubber gasket, allowed it to sit for about 10min, and then installed the pan.
If it's a cork gasket, you can coat both sides with a layer of Permatex 2B gasket sealant (dark brown stuff). I would coat the two neoprene end seals with silicone grease Dow Corning 111.
On my GM 3.0 V6, the service manual said the rubber pan gasket gets NO sealant of any kind. I think a thin layer of Permatex on cork is a good idea and it also helps keep it in place while you install the pan.
