First Vehicle: 360 V8, 178k, Mobil 1 10w30 every 3-4k since 65k
This motor has used close to a QT every 3k since I have had it. It doesn't have any significant leaks. At 150k, I began rotating Mobil 1 High Mileage formula every-other oil change instead of only using regular Mobil 1. But on some internet research, I have read many stories of other people saying that their vehicles also burned off Mobil 1, but when any other oil was tried, it stopped. This vehicle was recently retired as a daily driver. I am looking for a good alternative oil to try but there are no other full synthetic High Mileage oils I can find locally.
I want a High Mileage 10w30 oil. I am thinking of switching to Castrol GTX High Mileage formula since I can't find a good alternative to the Mobil 1 in High Mileage oil. My only concern is that conventional oils seem to absorb moisture more than synthetics. Since this vehicle will be driven once a month at most, would moisture aborbtion be a concern?
Also, I have heard that Valvoline Max-life & Castrol GTX High Mileage both actually have a squirt of true synthetic oil in their additive pkg? Is that really the case?
If the vehicle uses oil with ANY other oil, then I have no problem sticking with Mobil 1 High Mileage formula, but I at least want to try something else to see if it is only Mobil 1 that burns off since it has done it since I got it in 2001. I know a QT is not that much, but since others have had this issue with Mobil 1, I want to experiment. I just hate going from a full-syn oil back to conventional oil unless that is my only choice to get exactly what I want.
The other idea I had instead of Castrol conventional High Mileage, was trying some Mobil 1 10w40 High Mileage formula. But since it has used a QT between changes since it was newer, I doubt it has any engine problems that would truly warrant a thicker oil.
Second vehicle: 4.0L I-6, 72k, currently using Trop-artic 10w30 syn-blend, uses no oil between 4k change intervals.
This is a flat-tappet motor so I want to switch it to a on-energy conserving(more zinc, phosphorus, etc), but can't use Rotella because I want 10w30 and it is a CA emissions vehicle and I do not want to kill the 3 cats it has, but still want non-energy conserving to protect the cam lobes. It does have some oil seepage, but I still do not want to switch to a High Mileage oil yet since it is not High Mileage and it uses zero oil.
The only non-energy conserving, non-High Mileage 10w30 I can find is Mystik. As a bonus, it is also a syn-blend which is what I am already using so a switch to Mystik 10w30 seems like the exact oil I am seeking for this motor?
Any input, advice, or facts would be nice to help me; especially with the first vehicle because if I knew for sure that Castrol GTX High Mileage, or even Max-life were in fact a syn-blend then I'd feel better about switching it off Mobil 1. The other concern again is since it is not a daily driver, and full synthetic is better against moisture, then I might as well keep Mobil 1. I prefer non-energy conserving oil, but on the 360 V8, it is a roller motor and I am less concerned about wear.
Thanks fellas!
Thanks fellas!
