Originally Posted by gathermewool
Originally Posted by Ws6
Originally Posted by edyvw
When I was on the market for family vehicle, I quickly realized that proper solution is minivan. Everything else is just bunch of compromises. Now, that being said, since it is no option for you, here is what I figured out testing VW Atlas, Pilot, HL. I did not want to touch Subaru as it has CVT.
Pilot is much better family performer than HL. It is substantially bigger where really matters, third row and trunk. With third row up you actually still have usable space in Pilot's trunk. In HL, not so much.
Engine in Pilot feels as it does not have that much power, but actually it is very quick. HL engine is very anemic at lower rpm, an achievement considering it has more torque than predecessor, but due to Atkinson cycle, all usable power is very, very high. Not really good for that type of an vehicle. HL had serious issues with 8 speed, as well as Pilot with 9 speed (programming, though in HL there were hardware failures). Both transmissions are polished by now.
Both drive, well like appliance SUV's. It is meaningless saying anything about that because there is nothing to say.
Pilot has much better AWD in this generation, however, it is part time. Still, both will do much better job than FWD.
I also tested Atlas, and of three drives by far best, has by far the most space (actually it is not even close). Has extremely reliable engine that is in use for 15 years already. Transmission is same as Toyota's, Aisin 8 speed, except VW did much better job in programming. Also, it shifts faster than transmissions in Pilot and especially Toyota. Haldex AWD is much better than those in Toyota and Honda. ENgine sound is actually real perversion as VR6 has very specific sound.
I personally did not like the fact that VW tried everything possible to increase mpg which is as not as good as Toyota and especially Honda. Torque is much better at lower rpm's, but due to some changes in engine management, not as strong in upper rpm's as it is in other vehicles where this engine finds its place.
Personally, if I were going for family SUV I would go Atlas, but all pale in practicality compared to minivan.
In real world use, I have driven full time, and reactive awd systems and found absolutely zero advantage to the full time system in ice and snow. For offroading, maybe the fulltime has value, but almost all Pilot, Highlander, ascent customers are looking at awd from a prospect of snow, ice, rain, and at worst light gravel/sand/a bit of mud at the family bbq when parking behind the woodshed on the back 40.
I've driven several part-time AWD setups in inclement weather and it really does take some aggressive maneuvers to tell the difference. I remember one experience in a Ford Escape 2.0T (this was something like 6 years ago, IIRC) that was disconcertingly unpredictable when aggressively getting out into traffic on wet roads. The rear end power would come in unpredictably and then result in varying amounts of understeer (i.e., transition toward, but never reaching over-steer - never over-steer, for obvious reasons). The road was INCREDIBLY packed at all times and you need to either:
1. Wait for a small hole and gun it to get in or
2. Drive like the locals and slowly creep out into the intersection until traffic literally stops for you.
-----note: I found these intersection creepers to be incredibly stupid and dangerous
Subaru's AWD, especially in a turbo application, will usually produce a predictable amount of steering, even as VDC engages the brakes. In the snow, this usually results in some diagonal action instead of excessive under-steer in FWD or varying amounts of rear-axle power in part-time AWD.
I can also imagine that Subaru's AWD would result in slightly better getting-unstuck behavior, as you rock the vehicle back and forth to get loose.
During sedate driving in inclement weather between part-time and full-time AWD? No difference.
I found the reactive AWD was more predictable. The All-time was a Jeep Grand Cherokee with QD2 ELSD's F/R with 52/48 full-time split and 0-100 per tire, available. The reactive was a 2015 and a 2019 CX5 AWD. In snow and ice, both would slide if you tried to power through a corner too hard. Both were well balance though, and gave you exactly what you asked for. In direct acceleration, the Jeep would kick a little bit out of line while the CX5 would just GO until you reached the traction threshold of all 4 tires. I'd personally say they were equal to one another though, in ice/snow. Offroading those ELSD's win though.
