@High Performance Lubricants just finished formulating their new HDEO line and I got a stash to run in the new Duramax. Formulating and lab testing took a lot of time and work that paid off with an even better performing formula than their previous HDEO line. Yes, there is real lab data from their in house lab and an independent lab to back it up. Maybe Dave will chime in on the new formula.
I took a sample tonight of the factory oil that I drained at 2,500 miles. I will cut the filter and post here in a few days when it finishes draining. The plan is to run the new HPL oil for about 200 miles, then sample so we can see how much contamination there is from the leftover factory oil, then sample every 5,000 miles and drain when the data shows an oil change is needed. The first 5,000 mile sample should be about August 15th.
