Properly break in engines? how so?Depends. Factory oil can contain higher moly/additives to properly break in engine.
On my new (at the time) 2017 Infiniti Q60S w/VR30DDTT engine, I performed the 1st oil & filter change just after 1k miles. I followed the 1,200 mile break-in recommendation in the owner's manual, which noted to keep under 4k rpms and no jack-rabbit starts.
Here's the UOA, and yes, the FF did contain a higher ppm level of Moly:
After the FF was dumped, the next change was PP 0W20, then Castrol Edge 5W30, and Valvoline Modern Engine 5W30 for the last 3 OCIs and currently in the crankcase.
The recommendation in the manual is quick and dirty . 5k oil change with 0w-20 Synthetic . That's it . The maintenance reminder in the dash display is set at 5k .
I rent often and seldom see a car with even 30k …I wonder how rental car companies and other fleet buyers handle this very delicate situation...
I don't know what the OCI are for the Diesel engined Audis.
I think it might be the same 19k or 2 years.
I think I am going to change the oil at around 2/3000 miles.
With all the talk about the 508/509 0w20 being green in colour I thought it would look different on the dipstick.
But it looks the same.
Enterprise HQ is very strict about OC"s every 4-5k. If it's just before,at, or over, the computer will not let them rent the vehicle. Years ago I used Enterprise often and would check the oil when I got it home. A couple didn't show oil on the dipstick. I put a qt in one because I didn't want to get stranded on the DC beltway. I believe they are strict because they used to have problems and it's part of the contract with the manufacturers.The early first oil change has always been a good idea. In UOA after UOA, wear metals and particle counts are way up on the first oil change. Don't forget that those particulates do cause and promote certain types of wear.
I've been a fan of early first oil changes for over 45 years. It's no surprise I get more miles from my engines than others. Often considerably more. We've had fleet Fords with over 900K miles, and no cam chain or phaser problems. Yet others find themselves changing chains at 100K and have nothing but phaser problems.
That's not for the gasoline engine .Not so quick and dirty. From the Manual-
This vehicle is equipped with oil change monitor. It calculates engine oil and filter change interval base on driving conditions. Driving in severe conditions will shorten the engine oil and filter change interval. When the Engine Oil – Service Due Now warning appears in the vehicle information display, the engine oil and filter need to be replaced.
Re-read the manual.That's not for the gasoline engine .
