Hello Everyone,
Bought a 2009 Yamaha FZ6R which if you're unaware has a de-tuned R6 600cc inline 4 in it.
I changed out the factory fill at 150km and changed the filter. I used a new Yamaha OEM filter but couldnt get the recommended Yamalube 10w40 oil so I had to put in Castrol 4 stroke motorcycle oil that I found at walmart. I then dumped that oil out at 575km and replaced it again with the same Castrol oil and left the same filter on. I'm planning on changing both oil and filter at 1000km and then I figured I'd go to a regular post break-in routine.
My questions are:
1) I was planning on running the Yamalube 10w40 and OEM Yamaha filter but after reading this forum I'm lost. No one is recommending Yamalube. What oil should I be using and during the summer is it better to switch up to the 20w50? The owners manual says API service SG type or higher, JASO standard MA. It also states not to use diesel spec of "CD" or oils of a higher quality than specified. And not to use "energy conserving II"...I keep seeing this Rotella name and when I looked at the stores for that its deisel oil. Can someone tell me what thats about? I see amsoil motorcycle oil and thats about 10$ a litre...was going to try that out but its kinda pricey. Any recommends???
2) Other than the oem filter I'm lost for another. It seems that its the same as a honda civic filter that I have about 3 laying around from a 2003 I used to own. Should I just stick with the OEM filters from Yamaha? They are almost 20$...Or is the K&N filter better? I dont think there are others that I can find around Toronto ON easily...The bike shops that I go to know pretty much nothing about oils and they just want to sell whats on the shelf...
Thanks for any help!!!
Yamaha newbie :)
