Why do mechanics often assume because a transmission has been recently filled with new ATF, this is what caused the transmission failure? Do mechanics assume that recently changed motor oil caused engine failure? Because of this ignorance I have heard mechanics tell customers that they recommend not changing ATF. Needless to say I will not recommend someone use those mechanics in question. I tired to ask the mechanics that do not recommend ATF service that the ATF should be changed more to avoid the transmission failure but many are just plain stubborn.
