New Amsoil MC 10W-40 94 Zx-11 761 miles
Vermont
I finally installed some of the new Amsoil 10W-40 motorcycle oil, which I sampled at 761 miles and 1500 miles, in order to compare to other samples I've had done. Here is the 761 mile sample.
code:
Oil            Amsoil 10W-40 M/C
Miles on oil   761
Fe             16
Cr             0
Pb             0
Cu             4
Sn             0
Al             9
Ni             0
Ag             0
Si             5
B              16
Na             8
Mg             179
Ca             3067
Ba             0
P              1172
Zn             1506
Mo             40
Ti             0
Va             0
K              0
Fuel           <1
[email protected]      11.57
Water          0
Glycol         NEG
TBN            9.1
This did include about 4 ounces of Lube Control at the start, but it still seems to have sheared quite a bit. The wear numbers are about normal for my bike, maybe a bit elevated. My 1500 mile sample results should be coming soon.
Cedar Park, TX
iron is high. copper is on the verge of being high. zinc looks good. how hard are you twisting the right wrist in these 761 miles? how much oil does your bike hold?
nicrfe1370
Vermont
The wear metals must be due mostly to the way I ride. I have fun, but rarely do I approach my bike's 11500 rpm redline. The sump holds 3.5 quarts, and I use and change a Kawsaki OE filter every time I change the oil. Can iron be coming from the clutch?
Cedar Park, TX
i guess you need to find out if you have steel clutch plates or not. i am gonna guess yes. so that iron would be from the clutch and be quite normal. however, then where is your aluminum coming from? maybe the clutch basket itself? with the exception of iron, copper, aluminum and the poor viscosity, looks good. i can't wait to see the 1500 mile uoa. how much are you paying for this oil that sheared out of grade in a mere 761 miles? i'll guess the vis will be a low30/high20 by then.
wytheville, va
How much are you paying for this oil that sheared out of grade in a mere 761 miles? [LOL!] Seriously, though, we may be able to credit the additives with the thinning effect. I would try an unadditized dino HDEO like Rotella (15W40). You'll see better numbers, and you'll save enough on your next oil change to pay for the UOA. [Wink] Dan
Florida /Texas
I think I saw where the new oil has some kind of additive and makes that iron reading high. Something to do with the new longterm storage stability with rusting. It would be interesting to see the results without the additives though. Cause this oil was not supposed to shear in 761 miles like that. I've been running the old 20w50 ams and I run very close to redline frequently, also sustain it for long periods of time. I do 2000 mile changes. That oil also reduced my operating temps. The cold comes soon , so I'm going to switch to 10w40 Redline, see how it does with my 36,000 mile clutch.
nicrfe1370
Vermont
Well, upon checking my other reports, I have to retract the statement that wear might be a bit elevated. It's actually normal, or even a hair less than anything else I've tried.
