Couldn't agree more with Mystic, Kompressor, and CAtedster. I guess I'm just a bit cheaper...as in way, way into Cheap Bast*ard territory. With 36 cent/qt (after rebate) Citgo oil and $1.99 (on sale) STP filters, that equals $4 per oil change, or $8 per year. I blew more than that at Denny's the other day for lunch. So why NOT change oil???
I'm trying to find a "car talk" article in the L.A. Times from about two years ago which talked about the rumored (at the time) Toyota sludge problem. The reporter interviewed a Valvoline engineer who told him what typically starts to happen to motor oils at given low/no-maintenance milestones (7,500 mi, 10,000 mi, 15,000 mi.). I seem to recall him saying that any conventional oil can go 10K miles before it starts to seriously deteriorate due to contamination and additive depletion, and by 15K miles one can expect gelling, sludging, and other engine-threatening conditions. (This is with a stock, neglected filter as well.) Keep in mind that many bypass valves might only flow around 3 gpm, so if a factory type filter is clogged due to neglect, ony minimal lubrication will be realized, even if bypass is fully opened. So in talkin' "old oil" ramifications, maybe we're missing a bigger problem -- old oil filters!
[ November 07, 2003, 06:49 PM: Message edited by: TC ]
