hey all...
I have a small block Ford set up for drag racing and am looking for suggestions for what oil to run...
I would prefer to stay away from $15/qt Royal Purple, $20/qt Mobil 1 Racing, etc... The engine has a wet sump oiling system and takes 10 quarts per oil change.
The engine is set up with .0023 rod bearing clearance and .0024 main bearing clearance. Piston to wall clearance is .0085, as suggested by the piston manufacturer.
This is a naturally aspirated 355 cubic inch engine with a hydraulic roller cam in front of a three speed automatic. I shift at 8400 rpm and cross the stripe at 8700 rpm.
The engine is "chilled" between rounds down to ~50*. Water temp after a pass is usually ~130*.
I have been leaning towards Lucas Pro Stock 0-20 oil but is only available mail order.
I have also considered Mobil 1 5w-20 with a bottle of ZDDPlus. This would be the most economical solution and also the easiest to obtain from the local Walmart.
Any and all suggestions are appreciated...
