I recently bought a used Toyota Landcruiser (99) with 58K miles. I changed all fluids and had the timing belt changed and the water pump along with all new hoses and belts. Also changed the thermostat and the rad. cap. Cooling system was flushed and filled with Toyota compatible Prestone 5 year 150K mile antifreeze. After an intial 1K mile run-in all new hoses were checked and some fluid had to be added (not much) to bring it to the full line and it has stayed at that level for the last 2K miles so everything seems to be OK. How long would you guys recommend running this new antifreeze before another flush and fill?
