Need Quick Answer. Does BMK-11 or BMK-13 Include
Palm Beach FLORIDA
Include filters ? I just bought the preferred customer thing through pablo, ordering oil. I'm not sure whether i want the BMK-11 or the BMK-13 I think the 13 will be an easier install since I dont have to find pressure and tap the valve cover etc. and it relocates BOTH filters (a pain to access on my tacoma anyways) Price difference is only 20 bucks.
Do I need to order filters or does it come with filters, it is not clear on the amsoil website. Thanks guys
No the filters are not supplied, because they don't know which ones you'll choose, for example here is what comes with the BMK-13:
Code:
1. Filter Mount Assembly 1 BK-209
2. Allen Head Plug 2 BP-191
3. 1⁄4 20 x 1 Hex Head Bolt 4 BP-23
4. 1⁄4 I.D. Washer 6 BP-21
5. 1⁄4 20 Self Locking Nuts 8 BP-22
6. Adapter Fitting 3⁄8 NPT-1⁄2 JIC 2 BP-190
7. “O” Ring Fitting Adapter 3⁄4”-16 x 1⁄2 JIC 2 BP-189
8. Hose Fitting 4 BP-260
9. 13⁄32 I.D. Hose 8 BP-250
10. Spin-On Casting 1 BP-159
11. “O” Ring Small 21⁄2 I.D. 1 BP-196
12. “O” Ring Casting 1 BP-160
13. “O” Ring Large 31⁄8 I.D. 1 BP-162
14A. Thread Adapter 3⁄4-16 (white) 1 BP-163
14B. Thread Adapter
13⁄16-16 and 20 mm-1.5 mm (blue) 1 BP-164
14C. Thread Adapter 18mm-1.5 mm (red) 1 BP-165
14D. Thread Adapter 22mm-1.5 mm (yellow) 1 BP-166
15. Mounting Bracket (top) 1 BP-194
16. Mounting Bracket (bottom) 1 BP-195
17. 1⁄4-20 x 11⁄2 Hex Head Bolt 4 BP-185
18. 1⁄4 I.D. Fender Washer 4 BP-186
Plastic Tie 2 BP-46
Thread Sealant 1 BP-198
Instruction Sheet 1 BP-152
Here's the product brochure which shows the filter choices: http://www.amsoil.com/lit/g1092.pdf
