in regards to previous post about thread sealant, the service manual says to retorque cylinder head bolts (to 90 lb-ft) after first 20 hours of operation. I have 40 hours on the motor, and will be checking the valve adjustment tomorrow along with some other maintenance.
Does the following sound safe to do: either loosen, or remove and apply thread sealant, one head bolt at a time, then retorque to 90 lb-ft. There's 10 head bolts holding the head. The only concern I can see is the intake/exhast manifold that's mounted to the head, but since I'm doing one bolt at a time, it should be ok, right?
I figure this would be good to do now since I'll be loosening all the rocker arm nuts and will have access to the head bolts.
Motor is a 2002 inline-4 3.0L Mercruiser (GM block).
