Hello everyone!
I'm new to the forum and this is my first post. I own a 1947 Buick Special 4 dr sedan with the original Buick Fire Ball ohv 248 ci straight eight. It has babbit rod bearings and cam bearings. No oil filter (from factory) .
I had the valve train rebuilt with new springs, valves, guides, rebuilt oil pump and the cylinders re-rung with standard rings. The rebuilder put in 10w-30. It runs with 112 lbs in ea. Cylinder (6.5:1), 30 lbs oil pressure at 500 rpm hot idle, 42 lbs at speed...all are factory spec. The engine does still leak a little from the rear main seal, and I do see some blow-by in the valve cover. Nothing in the draft tube (pre-PCV) or exhaust and my AC 48 (NOS) standard plugs look good.
Factory calls for 20w oil down to 32* ( no degree symbol on I-pad [censored]?) below that temp it recommends to substitute 10% kerosene! So what do you recommend?
0-20?, 5-20?, 5-30? Stay with 10-30? I do add zddp to my oil as it has flat tappets. I read lots on this forum but could not find anything specific. Any one out there familiar with vintage iron? Thanks, and sorry for the long post.
-3onthetree47
-3onthetree47
